spot lights | on ElectriciansForums
Discuss spot lights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
newcastle
Im changing some spot lights to fire rated and have found there wired in T+E do i have to change it to heat proof flex or is there a way around it as customer doesn't want any damage to ceiling and there is a tiled floor above.
I'd go for the Clic Flow connectors, then you can connect the existing T & E in the ceiling then use the heat resistent cable to connect the new lights to the "plug" and then clip them together. Saves some messing around up a ladder with a screw driver.
There are downlighters on the market with the heat resistent cable and click flow ready attached.
Reply to spot lights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
I think your profile pic will scare him away 🤣🤣
I was considering that, however the loft isn't boarded, not exactly the lightest 🤣 I was hoping I wouldn't have to do that but maybe that's the...
