Spot the electrical crime | Page 2 | on ElectriciansForums
Discuss Spot the electrical crime in the UK Electrical Forum area at ElectriciansForums.net
Risteard
Supporter
V.Nearly Esteemed
Derry, Ireland
Spot the electrical crime committed at approximately 8:45 in this video.
I can follow that argument when say a socket face is attached, as the socket earth is connected to a metal bush that the screw sits in, thus bonding earthing the screws and back box.
however this is not the case for most light switches and blank plates.
except grid switches.
corrected that bit for you. bonding relates to extraneous parts. sorry to be pedantic. :D :D :D
I hate this.. its rough. I'm pretty sure there is stupid regulation that state as long as the surface area is less than a certain CSA it doesn't require earthing as long as it is RCD protected.
I'm going to try and find it now ?
don't think your going to find it,
best of luck.
410.3.9
Bullet point (iii)
I would post it but that would be illegal and against forum rules.
hmmm, maybe.
if the back box is not accessable.
but you have to admit it is wrong/poor work?
410.3.9
Bullet point (iii)
Cobblers. a single back box is > 50mm x 50mm, the screws can come into contact with a person. and you can't say that a connection would be difficult.
hmmm, maybe.
Completely agree, its bad workmanship.
I personally don't agree with that regulation. The only reason I found it was because I've previously come across the same issue in a new build and I had to double check the regulations before telling the customer to complain.
The point is that the screws can’t be gripped and can’t make any significant contact with the human body other than a finger tip, the back box can’t be touched at all.
Poor that it wasn’t earthed tho no defence against that, as you said it’s not difficult to do.
I must admit that my version of GN1 is the 17th Edition Amendment No. 3 version rather than the 18th Edition version, however it states:
"However, the IET takes the view that flush metal accessory boxes should be considered to be exposed-conductive-parts and connected to the main earthing terminal by means of a circuit protective conductor."
So regardless of what any Regulation states about screw heads the actual backbox still must be considered to be an exposed-conductive-part, which was my point.
Says the same thing in the 18th edition gn1 and gn8
This is one of those things that annoys me...
We all agree that you should earth metal back boxes...
Like I said I came across the same issue in a new build and the customer was ready to complain but I stopped them in the end, only because of that regulation I posted earlier. I wanted to be 100% sure I could back up my arguement. The guidance notes are obviously very clear, however that regulation is not.. wish the IET would be a bit more specific sometimes.
Reply to Spot the electrical crime in the UK Electrical Forum area at ElectriciansForums.net
...and there was me thinking some on here had gone over to the dark side
Just have a look for plug in power monitors. Much quicker and cheaper probably
