Spot the mistake ++++ | Page 2 | on ElectriciansForums
Discuss Spot the mistake ++++ in the UK Electrical Forum area at ElectriciansForums.net
Doomed
Dorset
[ElectriciansForums.net] Spot the mistake ++++
good neat job
Perhaps it is an intermediate switch that has been wired as if it were a double pole switch.
Nah.
You’ll not break the circuit using an INT switch.
It either is straight through or reversal of L1&L2.
Nah.
I think that's why Richard said it. We're looking for something that has been done incorrectly.
So what are you going to do next?
All existing wiring is surface clipped, so I had been asked to chase out and flush it in. The client has now accepted my recommendation to change the two way switching wiring and also re route (with new) wiring in loft so he board it.
Effectivaly a partial re-wire now.
Effectively a partial re-wire now.
Your customer sounds a decent person ............ they have listened to your input and acted on it.
Nice one!
How were we meant to see that with the clues given?
Two twin and earths at an intermediate switch is not uncommon if it’s a central joint box install.
ikr feed at both 2way switches, switch wire at 1 switch, then a t+e between for strappers picking up intermediates
the feed at 1 end is obviously not used and terminated into a connector
Reply to Spot the mistake ++++ in the UK Electrical Forum area at ElectriciansForums.net
Your biggest mistake is admitting to a mistake.... If theres no witnesses, it didn't happen. However.... A few golden rules.... Never trust...
What was the assossors name? Was it warren by any chance? Did you get it sorted in the end?
