L
lofty84
So I am going to be putting some spotlights in a bedroom when Ive done them before its always been via running a new lighting circuit from the board. This time theres already a pendant fitting in the room so I was going to re wire everything in the rose into a junctionbox which I hope is ok. In regards to the switch line which I will snip of so I dont loose it does this go with the lives?
Also is there a method for getting you spolights into possition the most efficient way or is it just a case of putting them in by eye hoping to avoid and joist's
cheers
cheers
