G
Gary11
Hi, I have x4 spotlights recessed into my bathroom ceiling, they're the gu10 fitting 50w bulbs on a pull cord dimmer switch.
Recently I painted the ceiling and to avoid getting paint on the lights, I pulled them down from their holes. When the paint was dry I put them back in, one of them twanged in on the spring clip a bit harder than I would have liked (if you know what I mean by that?), anyway when I put the lights on the one that went in a bit roughly was shining extra bright, so I had a feeling it was ready to blow, so I left it to do just that before replacing it.
A few days later I was at work and my wife phoned to say all the lights were off in the bathroom, so I said flip the switch on the circuit board and they should come on; which she did but the lights remained off. When I got home I checked the switch on the board and it was in the on position, but no lights, so I thought well maybe they've all blown? Thinking this was probably unlikely but not sure what else to try I swapped the bulb that I knew was probably at fault and one other too, but still no lights.
Is it possible that the switch has faulted, when I assume the "bright bulb" blew?
Any advice would be appreciated, thanks.
Gary
Gary
