Spotlights | on ElectriciansForums
Discuss Spotlights in the UK Electrical Forum area at ElectriciansForums.net
J
Jamiemfc
Good evening
Looking for a few tips on the best way to open out cut outs for spotlights that are already there, got a job on tomorrow and the customers already bought the lights but the fittings theyve bought need a 10mm bigger cut out than the existing spot lights! Any tips greatly appreciated(im sure therell be little gadget out there someone knows of)and before anyone asks yes im a qualified spark just used to a more industrial setting(steelworks)!
Jamie
I use a steel rule, in your case line it up 5mm either side of the cut out, make a few marks around the circumferance and then connect the dots. Cut it outwith a padsaw, job done. Thats how i do it anyway, but if there is an easier way i would love to know it
Get a bit of foot square mdf or similiar and drill your appropriate sized hole through it then hold this over the old downlight hole and use as a guide
just make sure you apply ehough pressure on the wood so it doesnt slip and go slow with the drill at first
Pad saw. Or if you want it perfect , get a small sheet of wood and cut a stencil with your required hole size. Screw it to the cieling to hold it in place and cut. Repair screw holes later.
Reply to Spotlights in the UK Electrical Forum area at ElectriciansForums.net
