sppedfit u/f heating and water
stidge
Hi All.
I am at job where there is a speedfit U/f system (8 zone panel) a radiator system and a Megaflow cylinder. I think its possible to connect all through speedfit panel ? I have been supplied with 3 x programmable stats,there are 3 zones.I have wired to a seperate stat for the Rad system.The megaflow is a distance away from boiler and manifold but i have pulled in 2 x 5 core cables as there is the Cylinder stat and motorised valve. Any advice or suggestions or Diagrams on easiest way to put all together will be greatly appreciated. Also What sort of time clock (if any) will i need to fit ? Cheers
C
Chris Taylor
C
