F
fylthespider
Hi chaps,
come across interesting one whilst sorting another problem out.
modern three phase board in a small private care home. (i was checking why the spa rcd was tripping)
Took the cover off the main switch ( to check Ze) and found a 1.5mm fp200 cable connected to one of the incoming phases. This is then feeding 13a fused spur (outside main C.U) which then feeds to sprinkler system control unit.
owner said company that installed sprinkler system did it (cos they have to have an un-fused supply) and they are responsible for maintainance, certification, etc.
now, its not my problem, but it doesn't sit right with me.
we've got about 1m of 1.5mm fp200 hanging on the 100A incoming main cutout fuse.
even tho its all enclosed within a metal clad CU, surely this carn't be right?
I know sprinklers are a law onto themselves but this certainly contravenes 17th and common sense.
Going to ring tech help (napit) tomorrow but any thoughts/info on sprinkler systems would be appreciated.
Yours, (not sure if going on war path or not)
phil.
phil.
