B
buzzbuzz
Hi
I'm adding a fused spur (6A) to a 32A ring to power a central heating boiler. Does the spur cable have to be the same CSA as the ring (2.5mm) or can I reduce the cable size to be minimum size required for load on that spur ? Also, is it then treated as a radial circuit for sizing/speccing etc?
Buzz
Buzz
