Discuss Spur from a lighting circuit. in the Australia area at ElectriciansForums.net
Bit embarrassed to ask this, but can you run a spur from a lighting circuit? If so, is there a limit to how many lights you can put on it?
Can find anything in OSG or BGB.
As Kit says watch out for max ZS, cable rating and esp VD as that (as Im sure you know), is more critical on lighting circuits. Compare R1+R2 to GN3 to see roughly what you have in meters.
Reply to Spur from a lighting circuit. in the Australia area at ElectriciansForums.net
