A
andyh
I'm looking to spur off the ring main to supply an FCU for a fixed piece of equipment. The spur will be from an existing double socket. Question is whether it is ok to use 2.5mm cable or whether the connection to the FCU should be in 4mm? The FCU is fused at 13A so it can't draw more than this but what happens if there's a fault in the ring main supplying it causing a current in excess of what the single 2.5mm can take?
