Just need to check something. Sparky installed two new plug sockets. To do this, cut into the main ring, put a junction box in, one cable out to socket. Then from there connected one more plug. I understand to spur off a spur you should use a fuse between them?
It is part of our wiring rules. the idea is that not all of the outlets will be used at once. It is the standard in all domestic wiring and seems to be working fine.
