Spur problem? | on ElectriciansForums
Discuss Spur problem? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Preston, Lancashire
Spur off a spur in 2.5 T&E off a 32A ring circuit in a utility room running a washing machine & a tumble drier. This was reported on a recent PIR of a rental property and the landlord would like it corrected,
The problem I have is if I install a FCU then the customer can only use 1 appliance at a time (apparently not an option in a busy household!!).
So my solution would be to fuse the spur with a 20A mcb in a small 2 module enclosure, which will protect the 2.5 T&E from overload and still allow use of both appliances at the same time.
Can anybody see a problem with this?
I know its not the norm but to incorporate the utility room into the ring circuit will require ripping up a tiled bathroom floor, which the landlord is very keen to avoid.
could you not run a leg below the utility room ceiling ( safe zone) or mini trunking and extend the ring?
Done the 20 amp mcb trick myself, can see no problem. In theory if you have 2 single sockets spured from the ring is this different to 1 x twin? But as you know the load may exceed the 20A for a 2.5 best play it safe. As a thought you could limit one of the washing machine socket with a spur if you knew the load. If less than 7 amp 13 + 7 = .... erm 20? Will look tidier if done in a dual box and labelled 'MAX 7AMP' than a small DB.
OK , so your solution seems the only way. can't see anything wrong there, only that if 2 machines are on the heating cycle at the same time, they could trip the 20A MCB.or you could sell them a washer/tumbler combined.
Not the ring imbalance monster again!!!!!
If 2.5mm2 T&E is rated at 27A (clipped direct) then how can a 20A fused spur overload either leg of the ring?
As mentioned in post 3 it is spured off the upstairs ring which is usually very lightly loaded.
Reply to Spur problem? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Cheers guys, enjoyed reading all the responses. I'm an apprentice and it was a conversation that came up at work between two electricians...
2 3
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
