N
N2ETC
Hi just a quick one, I've got to re-wire a socket as the old socket is very badly damaged. The socket that needs re-wiring is spurred from an above socket but trying to get the whole wire out may prove difficult. The end of the wiring has been damaged and if I can chase up the wall to a clean bit of wire I would like to put in a junction box. My only problem this is a wall that will then need plastering can you get wall junction boxes or if not what can you use please. Hope this makes sense?
