Spurred power via fcu and possibly a light. | Page 2 | on ElectriciansForums
Discuss Spurred power via fcu and possibly a light. in the UK Electrical Forum area at ElectriciansForums.net
E
entech
Hi all, I was looking at having power and light. Is it possible to spur from existing ring main via 13 amp switched fcu and 2.5 mm to supply one double socket outlet and then come off that via a 3amp switched fcu and 1mm to supply one pendant light fitting. It will all be surface mounted so will be visible.
Reply to Spurred power via fcu and possibly a light. in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
hI Gent's. I I can explain this spur line briefly, maybe someone can help me? Everything is Spur, no rings. Inside of the house and main fuse...
