spurs | on ElectriciansForums
Discuss spurs in the DIY Electrical Advice area at ElectriciansForums.net
B
Bigib
hi everybody or anybody,
this is my first post thread so I'll keep it simple as I can. I need advice on electrical spurs. I have spurred off a double socket but I need another socket (preferably a single socket) to plug in a washing machine. would this be too much spurs off a double socket??? Thing is the washing machine will need to be also linked to a fixed fused switch with the single plug in lower half of the kitchen top. is this acceptable to do?? or maybe can I just put in a junction box between the double socket to the new single socket?
any advice help would be much appreciated.
you are only allowed 1 single or 1 double socket as an unfused spur. in your case, fitting a FCU for the washing machine would limit the possibility of overload on the cable after your first spurred socket. a better way would be to make the first socket a part of the ring, then spur off, although what you suggest is acceptable. if in doubt, consult a qualified electrician.
thanks for reply. I understand I can only spur off one double socket & that would be straining the power enough but it's ok to add a single then wire that to a FCU for washing machine is that safe enough ? I already made a back box for double socket & linked it to from existing D socket so I'm already committed from that spur.Im aware the washing machine FCU needs to be top half of the work top but I can have a plug socket for it below the worktop? hope u know what I mean, trying to keep it simple. if this isn't a option for washing machines plug. I have another single 2.5mm cable other side of room can I make a junction bix from that to feed the new single plug FCU?
for a washing machine, it's standard practice to fit either a D/P FCU or a 20A D/P switch above worktop, feeding a single socket below. this is to be able to isolate the appliance without having to pull it out to get to the plug/socket.
Get someone qualified to do the work mate
Reply to spurs in the DIY Electrical Advice area at ElectriciansForums.net
It depends on where that SFU 'sits' in the circuit. If it's there as a courtesy isolator for the fridge socket then potentially yes as it could...
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
