Square D MCB to RCBO | Page 2 | on ElectriciansForums
Discuss Square D MCB to RCBO in the UK Electrical Forum area at ElectriciansForums.net
Sheffield
[ElectriciansForums.net] Square D MCB to RCBO
Hi All,
I have just been to to view a job on my way home. The customer is asking for a new double socket immediately below the consumer unit (that's convenient!).
It's an old Square D board without an RCD in sight.
I guess it would be very easy to install an RCD socket outlet - spurring from either the kitchen ring or 'main ring' one way or the other.
But I was thinking - probably for the same price - I could swap out the MCB for an RCBO, though it would be second hand, but with the obvious benefit of providing additional protection for an entire socket circuit.
I thought of suggesting a board change - but that seems a bit OTT when a customer on a budget only wants an additional socket.
Question is then - what would you do?
Perhaps its not viable anyway - the MCB's are marked up as Dom, eg Dom32B6 - so am searching the web to see if a replacement RCBO even exists (by Square D/Schneider)...........
I thought I’d close out my own post properly.
I returned to site and removed the evil MK MCB (which actually seemed to fit OK). It was - as was suggested - an abandoned shower supply.
In its place I put an Easy 9 RCBO - put the kitchen ring on it, as well the FCU and socket the customer wanted (there is going to be a worktop between the two).
The RCBO fits perfectly, though is a tad bulky, and I would not want to try and squeeze one in a congested board.
All good.
Thanks to those who contributed.
Reply to Square D MCB to RCBO in the UK Electrical Forum area at ElectriciansForums.net
Ye smaller board (containing the RCBO'S) will literally be next to the MEMSHIELD, And hence the 32A MCB be simply feeding power to a 32A RCBO I...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
