T
TPES
I have Downlights and Fan to fit in a bathroom, the customer has one of the old Square D Qwikline CU's, where the MCB's clip into a kind of Live din rail, (like crabtree starbreaker CU)
I need a 6a RCBO Is there even one available..?
Any of you come across one?
I'll have to go in and ask, Ive spent a while looking online for one, I managed to find one website that does the correct type, but only go down to 10a, Not a 6a..
It has to be the QOE- model type.. i can find plenty of the other type Square D type rcbos
I had a look on the web and i'm sure square d and merlin gerin use similar breakers.
Merlin Gerin C60HC6R30
They are made by the same people "Schneider " I think so they would fit although it is against the law to fit
each others as they are tested differently at least thats what I have told by Senate staff .
Go down to your local Edmundson and if they hav'nt got any they will order some for you not a problem
Yes get a schneider one from most good wholesalers.
Not sure about a 6 tho, they might only do a 10.
Can't see why it's against the law, can anyone explain coz I've used tonnes of schneider RCBOs in Merlin boards.
Can't see why it's against the law, can anyone explain coz I've used tonnes of schneider RCBOs in Merlin boards.[/QUOTE]
I was told although they are made by same company they have different TESTS applied so if you put each
others mcbs in diiferent boards and you had a burnout for instance you would have no comeback
He quoted a case where a wholesaler knowingly sold Merlin gerin for Sq d board and was fined etc .
I personally wouldn't stress too much .Was just what I was told, May be an old wives tale
None of the links are to anywhere selling to correct type of RCBO, I can see me strugling to get one of these, I'll have to ask about in wholsalers, surely theres someone that can order me one in, from somewhere
Square D Qwikline RCBO??
Australia
TPES,
Romans99,
