N
nickblake
Yes youve read right them little pests its a school only one class effected,chewed through AV and power cables stripped the insulation off 2 meters of TWE chewed an extension cable into loads of little pieces , so how to solve the problem : what im going to do is rewire all the circuits in the roof space in SWA with Galve boxes and couplers into the light fittings All the AV wiring into steel trunking as its a short run ,and then install an ultra sonic pest controll , very small hatch only get a 2 meter length through it and cant surface mount below ceiling
have you guys any thoughts ; and yes i have contacted Walkers to see if they need a new supply of roasted squirrel for their crisps
