sseg connected to DB1, Main house electrics usage from DB 2
F
futurewired
Hello all.
I think i know the answer to this one but would just like to confirm it from you fellow folks from the forum
Im installing the sseg to the main CU where the meter is, but my clients main usage of electricity is from a distribution board in another part of his house.
when the array is producing electricity, it will still run through to DB1 and back to the Db2 and can be used as free electric, i know electricity will take the shortest route.
Just need to be sure.
i.e not flowing straight into grid, when customer is drawing electric from a distribution board elsewhere.
Bit of a tongue twister but a valid point, would appreciate your comments.
Dave
