J
jago25_98
I was given some audio plugs purchased by a friend from maplin with which to repair an audio system here at sea.
No matter what temperature I achieved on the plug the solder wouldn't take (yes I burnt out the nylon in the wire). I had a closer look. It's stainless steel. How would standard solder ever take to such a surface?
Sorry if this is a stupid question. I'm not a fully trained sparky, but am I missing something? A different form of solder required perhaps?
As I say, the nylon is removed from the wire and the wire is correctly tinned. I even tried a little flux with and without.
