Staircase LED lighting | on ElectriciansForums
Discuss Staircase LED lighting in the UK Electrical Forum area at ElectriciansForums.net
DHES
Evening all
I have a job to look at tomorrow evening
And the client has said they want staircase lighting (LED) as I have never installed these before I was just wondering how you lot have previously installed them and what manufacturer you use?
All pointers are gratefully appreciated.
Cheers
Sent from my iPhone using Tapatalk
ÂŁ15 a meter i was quoted for the better quality ones from wholesaler, you just cut with scissors and you need drivers to power them.. depending on length.
which will work well if open stair case,and sit under edge of tread.....
or the ones in plasterboard for better light and can be as low as 1w with good light
Reply to Staircase LED lighting in the UK Electrical Forum area at ElectriciansForums.net
The company Liteplan do replacement modules: Liteplan – The UK's largest emergency lighting component supplier. - https://www.liteplan.com/ This...
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
