staircase lighting puzzle | on ElectriciansForums
Discuss staircase lighting puzzle in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
F
firespark
A 10 floor block of flats has a common staircase.
There is only one light switch in the staircase located on the top floor.
How do you turn the lights on from the ground floor?
Reply to staircase lighting puzzle in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
I found out the answer from another forum...here it is, yes This will be your neutral for the receptacle. Add a pigtail and connect to silver...
It could be a slave switch where you would have a L in and a common wire out to a master switch.
