Staircase lighting switch | on ElectriciansForums
Discuss Staircase lighting switch in the UK Electrical Forum area at ElectriciansForums.net
Need some help with this please
I want to replace a broken staircase timer
The new staircase switch is a Contactum TSSL1
This has four terminals L N 3 4
It is triggered by a MK push switch Com Break and Make
I have tried to mock this up in my garage first but it will not work
Could anybody advise on how to wire this up.
I would post the diagram but need more posts.
When I tried, the light came on as soon as power was supplied, went off after timed period. but the push switch would not switch it back on.
I'm not familiar with the unit at all, whats the diagram in the instructions say? I expect you may have to link the live terminal to 3 and then 4 will energise when the timer allows the terminal to become active, but we need more really.
well just post up any old crap until you get to the required post count, I suspect at a complete guess terminals 3 and 4 are volt free, but need to see a diagram, or I will have to put myself out and google the model lol
[ElectriciansForums.net] Staircase lighting switch
Here is the wiring diagram
  • [ElectriciansForums.net] Staircase lighting switch
4 is definately a neutral connection according to the drawing, however it looks like dimming can be carried out also, I assume and could be wrong as I am not familliar with this model that any push buttons would be connected in between the link cable from terminal 3 and the positive side of the light connection (switched live) as standard 2 core parallel switches would normally be done so in a stairwell, no need for anything other than 2 cores between all push button switches.
As I see it on the timer it needs a L and N to operate the clock
the light will need a N and a SL
The switch send a live to the timer which energises the SL to the light
So I need a live at the switch
When pressed, sends a live to the timer
which send live to light
the timer counts down and switches the light off
But that does not seem to work
that is what I expected to see, but the timer you have there doesn't show the wiring to work that way, I would have suggested a feed to switches and from the switches back to the timer and then to the light, but this drawing doesn't show that, can you show all the writing as well as the drawing there.
probably just the way it is shown, but terminal 4 is probably the switch feed back from the push switches and then 3 out to the light, looks like 4 is a neutral connection though unless I have had too many beers tonight
Reply to Staircase lighting switch in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
There should be. Keep them all straight, insert two and then the third - don't twist them all together. If that doesn't work for some reason, use...
