staircore lighting | on ElectriciansForums
Discuss staircore lighting in the Australia area at ElectriciansForums.net
Farmelectrics
Wirral
the company we are working for are on a energy saving mission and have been for last few years we have installed a photo switch on staircore the staircore is 4 levels so we find incoming switch wire and divert to photo switch not hard at all so when the the photo cell switches lights off bingo the only problem is there is one light that stays on we have split all lights and belled out all ok the light in question that stys on as voltage on one of the switch wires why i dont no as we have identified the in coming switch wire any advise welcome
Without sounding like I'm trying to insult your intelligence (as I'm not!!) - are you sure that if you've got one light on permanently to a stairwell that it's not a maintained fitting for safety? Or has been made so remotely by some hash-up of batteries onto the switch line.
Personally i never have agreed with switching lighting in stairwells as they are a means of fire escape.were the photocell to fail there would be a problem with a few hundred people heading for the exits
Maybe an occupancy sensor would be more appropriate. If one fitting stays illuminated it's probably on some sort of UPS supply for fire or power failure purposes as Rockingit suggested.
rockinight your not insulting my intelligence nothing better than sparks talkin to one another lost count of times ive sorted problems out by doing so thanks for your thought will check your version out was all ways told as an apprentice there no such thing as i daft question cheers
So what we're basically saying is that you need to trace a cable? As in, the switch cable to that light.
Is this fitting not an emergency fitting? either self-contained or slave of a central battery.
If it's a slave it will have some form of FP cable to it, or is it a self-contained fitting with integral batteries?
Say if the lighting on the stairs was manually controlled & is currently switched off, fire breaks out and people flood the stairs in a mad panic, no one is going to bother finding the light switch.
Emergency lighting is only required to operate when the final lighting circuit fails. If the PIR does fail but the mains is still healthy, BS5266 says this is ok.
Reply to staircore lighting in the Australia area at ElectriciansForums.net
Did it work?
Thanks for the replies everyone, much appreciated. I've been in touch with our electrician as we're going to have him swap out some sockets from...
