stairway lighting circuits | on ElectriciansForums
Discuss stairway lighting circuits in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
n ireland
Hi
been working abroad for a few years and now back in the uk , question i have is in a stairwell in a sheltered housing scheme do the lights in the stairwell still have to be wired on the 1 circuit under the 17th edition ? stairs cover 5 floors
thanks in advance
(17th edition course booked for next month !!!!!)
Hi
Stair case lighting in multi ocupants houses(Flats) are desined to run on timers for resons
to save energey and to increase life limit of installed Lights
However if the staircase has no day light windows, the lights has to be maintained 24 hrs
if there is windows u may have 2 controls
Timer to switch the lights on specifiec times normaly 6pm-8am
however there is chance u may have photo cell in place to override timer on winter days
regards​
ah cheers mate, i have piped the lights in 25mm plastic pipe along the halls and wired the stairs separate but someone today mentioned that they thought the stairs now had to be on local lighting circuits to avoid the whole stairwell going out under fault ???? always something to keep you guessing eh ?
was above post meant for me ?
issue is with circuits not with switching mate
and for the record all lights are on pir`s
cheers
well long as you installed maintained lighting , you cover it wither way if a fault.. i just cut and paste that from a different thread . when you type a thread/post normally at the bottom of page similar posts come up....
Reply to stairway lighting circuits in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
Yes sir. Exactly that. Probably got about 8 individual switch lines. I could bunch to slim it to 6 if needed
