Stand Alone RCD | on ElectriciansForums
Discuss Stand Alone RCD in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Southend on Sea
Hello Everyone.
I had to change a socket in a landlord property (enough said)
Did a check on the RCD and found that it was not working.
Even though the flat only has an old 4way wylex the land lord will not go for a new board.
so my question is what tests would I need to carry out for this job if I just replace the RCD.
I.E would this come under minor works?
There are a standard set of tests that you'll need to do (see GN3) to satisfy BS7671 and Building regs.
A MWC will most likely need to be issued after the work has been completed.
it's a like for like repair, so not notifiable, but basic testing ( Zs, IR, RCD ) and a MWC. IMO.
Reply to Stand Alone RCD in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It can also mean lasts or continues for two years.
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
