Standalone door alarm | on ElectriciansForums
Discuss Standalone door alarm in the UK Electrical Forum area at ElectriciansForums.net
carter912
Tennessee
How do I make a door alarm using a detex reed switch, SDC electric key switch, and a federal siren? The concept is that when you open the door the alarm goes off and you could only turn off the siren when the with is turned using the key.
Reply to Standalone door alarm in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
That will only count when the alarm is active o/p said tamper. O/P doesn't seem to be in any rush to give more info, so I doubt anyone else will...
