Standard junction boxes with screw terminals | on ElectriciansForums
Discuss Standard junction boxes with screw terminals in the UK Electrical Forum area at ElectriciansForums.net
impish15
Trainee
Supporter
Bromley
Hi,
Hopefully I haven't made an error but I was speaking with another electrician and he said standard junction boxes with screw terminals can no longer be used anymore, is this true? I wasn't aware of this.
I fitted 2 in a loft last week (to replace a connection just wrapped up in tape) as that's what the customer brought now i'm thinking am I going to have to go back and replace and something like a wago junction box. The junction boxes I fitted are accessible and fixed not sure if that makes a difference?
Thanks in advance
The difference being the cable needs to be secured.
Wago boxes have built in strain relief so if the cable pulls, it doesnt strain on the joint itself.
If the junction box is secured, and the cables are firmly clipped before entering the box, there shouldnt be an issue.
Wholesalers still supply those types of joint boxes, so they must still be acceptable to use
ok thanks for the clarification on this.
Junction boxes with screw terminals are acceptable providing they can be accessed. As with all JBs, cables need cleating, and the box should be fixed, or fitted with adequate strain relief to prevent cables being pulled out.
Reply to Standard junction boxes with screw terminals in the UK Electrical Forum area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
