Stanley hacksaw | on ElectriciansForums
Discuss Stanley hacksaw in the Electrical Tools and Products area at ElectriciansForums.net
gaffer
offshore/Channel Islands
Popped into b+q tonight and picked up a stanley fat max large hacksaw for £14,apparently they are changing their range of handtools so might be some bargins if your quick.
Reply to Stanley hacksaw in the Electrical Tools and Products area at ElectriciansForums.net
Ok so just done a quick test on mine. Megger mft on high gives 0.30 Robin 4120dl on 20ohm hives 0.22 Robin 4120 on 200ohm gives 0.28 Bearing in...
An opamp problem: - At +input I have a 424uV!!! signal. I diminuate it as much as I could to be clear that it is not the interference problem. You...
