Star and delta motor wiring systems | on ElectriciansForums
Discuss Star and delta motor wiring systems in the Australia area at ElectriciansForums.net
R
rochra
HI, Am I right in assuming that if im using a 230v single phase to 230v 3 phase inverter to control a 1.1 kw motor, I wire the Motor in Delta wiring formation..
The plate does give me Rpms, hz etc for 230v and Rpms hz for 415 so im assuming its duel voltage, it has come new from the supplier wired as Star, Im guessing for the higher Voltage.. But as im using a 230v single phase to 230v 3 phase inverter, was I correct with the Delta wiring.. Im not a motor expert or anything, and don't often get involved in them, But this is the odd occasion.. Thanks for your reply as well.
Reply to Star and delta motor wiring systems in the Australia area at ElectriciansForums.net
I got this all wired in and working thanks to the help from James, absolutely top man. Do have a small issue with current imbalance atm, L3...
I have sent you my contact details where in the West Midlands are you? I am based north of coventry but travel the county and beyond you may...
