star delta motor .....extra stop/start....415v abb | on ElectriciansForums
Discuss star delta motor .....extra stop/start....415v abb in the Commercial Electrical Advice area at ElectriciansForums.net
whats the best and safest way to install a remote start stop system
on a star delta motor .........i can only seem to find remote stops in series and no starts
will it have to be a relay low volatge system ......
any info appreciate ....its for a church organ motor in cella organ on 3rd floor
star delta 400v supply no neutral cheers
[ElectriciansForums.net] star delta motor .....extra stop/start....415v abbok guys sorry for early post,early i know .. im thinking of using 2 relays and piggy back the push release start and push release stop
heres the drawing of the star delta motor 400v coil ....
First off you shouldn’t be exporting 400V control from the panel.
Just looked at the two wire drawing and it’s downright dangerous.
Tony is right, you would need to create in a low voltage control circuit i.e 24V and control via relays, its a bit of faffing about.
and i answered.....
lol, it seems you know exactly what your doing...........
right people im back (have we all calmed down ) touchy *******s ................
i mentioned the relays as an alternative as i wasnt willing to run a 400v start stop system in
as at the minute the old system ive replaced is obsolete...so sorry if i upset any of you
anks to anyone with constructive answers cheers (as for burning churches down are u a satanist tut tut)
and th
malcoa thanks for replying the imbosile was to tony not you m8
im thinking of using a 400/24v transformer, then relays to parrallel up the start and stop
il post pics of what was in and what ive replaced later
If you are going to use relays, if the equipment requires an emergency stop, then, please remember that the whole system will be classed as a safety related part of a control system, or, whatever they call it these days, so you will have to comply with all relevant safety requirements.
Reply to star delta motor .....extra stop/start....415v abb in the Commercial Electrical Advice area at ElectriciansForums.net
