T
tullynagrow
i have a panel with 2 no star delta pumps 39 kw 63 amps flc can anybody size cable for me length of run approx 100mts 1no pump is on standby but could start if pressure drops the cable has to be afire rated swa clipped to a tray running through an underground carpark the panel has 50 amp motor rated fuses the pumps are to serve a wet riser system eg fire hoses
