Hi.
I need to alter the configuration of this motor wiring from star to delta so that I can use a VFD to control it (hopefully). If I remove the star connection from the N terminal am I safe to assume that these 3 wires will be in the correct orientation/ polarity to make the delta connection i.e. they will be w2, u2 and v2? Hope I've explained myself properly. Can I also assume that the connections A = W1, B= U1 and C = V1?
