Super Dragpack
Hi guys,
After a 10 year break from being on the tools, and a 5 year break from the construction industry, it's time for me to make my move back. My initial trade was an electrician, so hence why I am returning to this first trade and not pursuing general building or plumbing work anymore. I have ONLY EVER accepted domestic work, and this will continue. I have no interest in non-domestic work.
Anyway, things have changed a lot since I started in this trade, so for clarity I thought I would document the logical steps needed to make a start as a domestic electrician, and I was hoping for any corrections or suggestions from you guys.
ALL THESE STEPS ASSUME EXPERIENCE AS AN ELECTRICIAN IN THE UK (i.e. full practical knowledge)
THEY ARE THE MINIMUM PERMITTED AND NOT A SUGGESTION - AS EXPERIENCE/SKILLS VARIES
1/ Obtain 17th Edition certificate (C&G 2382) (get latest books obviously)
2/ Obtain suitable and calibrated (certified) test equipment
NOTE: At this point you can happily perform your own work (and issue your own minor works forms), but will require Building Control to check and sign off almost all of your domestic work under Part P which costs a small furtune. Also best of luck trying to find domestic work without affiliate credentials!
3/ Acquire suitable PLI
4/ Contact your chosen affiliate - NIC, ELECSA, Corgi etc etc etc - and pay them their fee (cheapest I've found is ÂŁ370+vat)
5/ Complete 2 jobs - (suggested to be 1 major & 1 consumer unit replacement)
6/ Arrange inspector to come and view work, question you and test your knowledge
7/ If all well, you recieve your credentials and can now "sign off" and "Part P approve" your own domestic work.
8/ Steps 2 to 7 is renewed every year
