R
R&M
Hi all,
Yesterday I was asked to do PIR for a building with twelve flats. I like to share some of the really interesting Art-works I found there with you:
Some of this mess have been done by someone who is called electrician. But some of them are DNO jobs !!!!!
yes that is tale block installed by DNO.
Why shield is striped off??
PME block cover is broken.
This is top surface of one of main isolator, TOP surface !! what about IP rating? and no grommet (casing is metal).
Tales block screw hole is broken and lead doesn't close.
Interesting is this genius, whoever he is, he can touch cut out fuse but we can not.
Regards
Ramin
Regards
Ramin
