I've been asked to take a look at a proposed static caravan site where there is a single phase supply. It has a TT earthing arrangement. The request is to design a circuit that will feed 8 static caravans. The distance for a ring circuit supply cable to each of the vans is approx 200mtrs.
I'll just put my thoughts down and hopefully there will be someone that could steer me in the right direction.
From the Main intake, into an Swithed fuse.(would this have to be a 100A 100ma RCD?)
16mmsquared 2 core SWA set up as a ring circuit and buried at least .6mtr underground.
8 supply boxes with coin slot. 100A double pole switch, 20Amp 30mA RCD, 16A MCB attached to commando socket outlet and 3A for external light (requested by owner).
Each box would need and earthing rod.
I need to do some cable calcs just to make sure it's all ok but does it sound like I'm along the right lines? Any one know where to get the boxes from? Should I request another phase and increase the possible demand to each van? Is it ok to bring the 16mm up into the 100A double pole swtich and down to feed the next van or should I use a din rail mounted isco block?
Would appreciate a bit of advice on how to apply diversity to this please.
All comments really appreciated
