C
coxyboy
I was called out to a job today and found something I have never come across before....
when I got to the property the tenant explained what was happening - she was getting what she called a "shock" when ever she turned the lights on upstairs in the two bedrooms and the landing. So I tested to see if there was any voltage at each switch and there wasn't. But sure thing as soon as I touched the switch I got a shock. I would say it was more of a big static shock than a normal voltage shock. So I had a little play around to investigate.
ie removing each switch reterminating and making sure the earths were connected. But still no joy. I turned off the main switch so there was no power to any circuit but I was still getting the static from each switch in both bedrooms and on the landing.
Has any one ever come across this problem before? If so what did you do to solve the problem??
Any help would be much appreciated, thanks
Ditto.
Cheapo carpets. Disconnect the cpc and you`ll see it wont happen, assuming there is no path to earth elsewhere. Changing the switches to plastic ones or if they already are, putting plastic screw covers over the set pins will solve it. Cheaper than new carpets. May still happen on ovens etc though.
If you add underfloor heating to the mix, those pesky metal lights switches become lethal from static. Static likes dry atmosphere and its coming from the carpets. They might find its better in summer when the humidity rises.
Yep change switches to the ones that have plastic covers on the screw because the tenant is earthing themselves another thing is tell the customer to run the back of her hand on the wall or staircase either that ditch the cheap nylon carpet
I had this very same thing today but the only difference was each it was various light fittings on the circuit; it would either be on the fixing screws or the terminals themselves, either through my hand or i would get a small spark through my voltage testers. The other difference was that unlike nylon carpets it was mostly laminate flooring. Help......
Can you give a better explanation? What terminals and what voltage testers?
I was just using my combi check testers to check for voltage, it would happen at whichever terminal I put my first probe on. having looked at other threads similar to this I think it might be a build up of static from the laminate flooring.
I'm not buying the 'static from laminate flooring' theory to be honest. I'd test to a wander lead connected to the MET. Maybe do a Ze test first as well.
Did a ze test and it was more than adequate, I've just finished rewiring the place, it was only when installing a fitting that we noticed/kept getting shocks. there are a couple of those 28w 2d fittings that I've installed, could it be anything todo with the control ballasts within these? will do a wandering lead test tomorrow, thanks for the advice
Had a lad working for me many years ago that could walk up and down a few times then point his finger near the switch and get a spark to jump across to it told one customer the problem was down to the cheap (£4k) carpet he had bought didn't go down well
Isn't that why you don't see many Traffic Wardens directing traffic any more as they could just point a finger at a car and sent 1000s of volts shooting out of the end of their finger towards anyone who abused them?
If you check out the causes of static you will find that you can generate a few K volts just by waving your arms in the air !.
Well, since the fall of the Empire the Emperor has to work!
I was changing emg lights in a residential home a few months back . i was getting a healthy sock when pressing the down button on the lift. So I walked about scuffing my shoes on the floor then holding a 8w lamp touched the lift and the lamp lit every time. Made us all chuckle
The most likely explanation is that they are buildig a static charge,
then they touch some thing that is earthed ( metal switch plate )
and thus receive a tingle.
The solution is to change the metal switshs to plastic
so no more earthing thru switch plate.
Or change the carpet !
thinkher nylon carpet is worn out by now. thread is 7 years old.
Static shock from light switches even with power off??
coxyboy,
Zerax,
