Steam Bath Shower | on ElectriciansForums
Discuss Steam Bath Shower in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
R
rakooos
Good evening. This is my first post and apologize for my grammar. I need to wire a steam bath shower which has 3500w max 16amp. I know that i need to use rubber 2.5mm cable but not sure what spur i should install. Can i put this on ring circuit ? Many thank for replies.
It is possible to connect this steam bath shower to a socket ring. I will install it on 13 amp fuse spur. Thanks
Refer to post 3 for the answer to this question and it worries me an Electrician suggests putting a load of up to 16amps on a 13amp spur to start with?
Do you not have your Yellow reg's book to hand?
There are no shortcuts here, you need to supply a dedicated circuit for your steam bath/shower.
Reply to Steam Bath Shower in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
Traymate Shower tray Hi guys, This is my first post so apologies if this isn't the right section for the post. I'm a qualified plumbing and...
Jeefa
J
Duh!!! Just re-read Op's original post, it was converted to a RFC!
