Steam (iron) generator | on ElectriciansForums
Discuss Steam (iron) generator in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
K
KAS1
Has anyone had the problem with home steam generators (they seem so popular nowadays), with the tubing/cabling wearing through where it rubs against the ironing board during use. It's obviously a fail during the inspection as the protection has worn through and the rubber tubing / cable sheath is exposed and more wear and the high pressure steam will leak also the flex will wear to expose bare cables. Has anyone found a simple way of protection for the tubing / cable and or somewhere to get replacement tubing / cable ?
That kind of wear should be dealt with under annual laundry equipment maintenance within a premise or laundrette, in the case of commercial laundries. In the case of an household, as per usual they'll be disposable like washers, fridges, tvs and the like.
What's the make of it?
Reply to Steam (iron) generator in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
