Firstly Thank You for the opportunity to join your forum.
I have just bought a Steca (Studer) XPC 2200- 24 inverter second hand for my 24 volt solar system .
When I wired it up and turned it on with AC in and out connected the AC present light was flashing which means suitable AC is not present at the input (which it was) , on the AC out side after a few minutes this indicator light was also blinking which means the device is searching for a load , I had this output connected to an automatic switchover switch whatever was reaching this because the indicator light on it was flickering was not enough to make it switch to this unit. The battery status light was on 100% and the on off indicator light was at soms stage flashing which means 'the unit is temporarily turned off and will automatically turn on ' which I did not see.
