Steel Adaptaflex Cutter | on ElectriciansForums
Guest viewing is limited
Discuss Steel Adaptaflex Cutter in the UK Electrical Forum area at ElectriciansForums.net
T
theatrespark
Does anyone use a ready-made tool for cutting steel Adaptaflex / Copex? If so, where is an affordable place to buy one? Thanks.
  • [ElectriciansForums.net] Steel Adaptaflex Cutter
In truth,the better your technique,in using a hacksaw,the less fancy jigs you will require. Good quality blades,TPI to suit material type and size,slow start,full strokes in use,control at finish...
Base skills,that i find myself explaining to lads who did their apprenticeship/training,years back....just don't lend em' your best all-hard blades...:yes:
Reply to Steel Adaptaflex Cutter in the UK Electrical Forum area at ElectriciansForums.net
Large Format Tiles / Score and snap I need advice on score and snap cutting of large porcelain tiles, lets say, over 1000 mm long and at least...
SergeTiler
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
Recommended Sponsor News
Hi everyone,
Email
Time zone
Last seen
