V
Vitesse
I have a metal clad CU that I am currently installing, it's the MK Sentry one and I want to use the Wago Sprint glands on it. They make a Sprint gland that is 25mm and will accept 2 x 2.5mm T&E for a ring final. The problem is all the knockouts on the box are either 20mm or 32mm.
If I bought a step drill bit that will enlarge one of the 20mm holes to 25mm, will it do it cleanly and give me a nice clean cut enlarged hole? I have not used one before and I don't want to fork out nearly ÂŁ40 if it just makes a mess of the CU casing. Also if it does what I want it to do, I guess it would be a good investment to add to the tool bag with Amd 3 CU's now required.
