W
warkan
Hey guys,
I am pretty new to this field. We have a underground armored cable laid out for around 1.5KM -2KM from the plant(Power room) to a river pond. The job of the river pump is to pump water to our plant. There are two pumps rated around 60HP each. Only, one will be run at any time. The other is just for standby. Recently, we have been having a lot of problems with the cable such as shorting and burns. Temporary fixes are not helping the case. When we checked for voltage being received in the river panel, it was around 390V instead of 420-440V. So, I am wondering if the voltage drop is the reason for the cable problems. If it is, what rated step up transformer do I install in order to regulate the voltage back to normal ? What are the criteria I need to follow ? Any help is much appreciated.
Regards,
Warkan
Regards,
Warkan
