R
Res is futile
Hi. everybody. This is my first post on the forum . I have recently replaced a consumer unit for night storage heaters and have used a dual rcd board to comply with buried cables requirement. Rcd would accasionally trip during the night. I have isolated the fault to one heater. I have powered this from the day rate supply, and measured the insulation resistance to earth when cold and then again after half an hour of heating. The insulation goes from greater then 999 M ohms down to 17 M.ohms and as the heater cools it goes up again. I did not have the time to leave it and see if it tripped the day rate rcd. I am confused as in my limited exp with storage heaters, the resistance increases as they heat up and dry out. Have I got a faulty element or could it be another component, and if so is it worth trying replacing the elements ? Thankyou for any advice.
