A
acowx
Hi all, thought I would share this one,
Got called to a job today where an elderly gentleman's storage heaters weren't working at all, so I get to the job and do what I usually do with storage heaters and check the safety cut out on the thermostat, all ok??? Mmmm ok next switch burnt out nope??? The one storage heater is fairly new and only been installed 2 months ago, after some further investigation I found that the thermostat connection had been shorting out on the metal casing of the heater and when I had a look at the consumer unit I could see why the heaters weren't working anymore...
The breaker that supplied this heater had melted together with the other heater breaker...
Got to go back tomorrow and test, then replace...
The elderly man had a poor sense of smell and could not smell the burning, I smelt it as soon as I opened the cupboard door.
Cheers
Ash
Cheers
Ash
