J
jimmer
I have a 3.4kW creda storage heater tripping a Type 3 16A Federal mcb. I have insulation resistance tested both the supply circuit and the heater and all is fine and also fired it up on a plug top and it runs for 20 mins fine and trips no fuses at all. Its pulling around 14 amps so i would expect the elements to be fine and there is no visable signs of damage. Its only the next morning the client rings up and says the mvb has tripped. Is it possible the mcb has gone weak? or is there something else i am missing?
Any help much appreciated, cheers
