M
marcjano
Hi,
I'm replacing a consumer unit on an installation which has economy seven storage heaters.
Before heaters were on their own feed from the time clock(located next to meter). I think that I shouldn’t put two supplies in to one CU so do i need to replace with two CUs or can I just use one?
I have never wired up economy 7 before.
Also I am not sure about type of installation as there is no MET and only 3x 16mm2 protective conductors joined to main cut out. No RCDs installed. I am not sure as well How I should connect separate CU when there is no MET. Can I connect PC between CUs?
Any advice would be greatly appreciated.....
