Re#3 - i made an enquiry last Jul 18 - scroll down to bottom to see it - and then read GD's response immediately below.
I cannot see any good electrical reason why one cannot do what snowhead and I had in mind - one supply to the SH - but I gave up and put the renewal project I had in mind using these GD SHs in the pending tray.
Thank you for your email. The quantum heater is designed to only work with separate connections to an off peak supply and a 24 hour supply. Although some energy suppliers have now provided a single fuse box for the off peak tariff, the quantum heater is not compatible with this. You will need to have two separate supplies for the quantum.
The supply connection you have described has not been tried and tested with this product so we are unable to advise on this.
Please don't hesitate to call us on 0344 879 3588 or email us at
[email protected] as this account is not always monitored.
Kind Regards,
Heather, customer care
Heather Scott
Customer Services Advisor
A Millbrook House Grange Drive, Hedge End, Southampton SO30 2DF
T 0344 879 35 88
E
[email protected]
Sent: 07 July 2018 09:59
To: GDC Pre-Sales <
[email protected]>
Subject: dimplex quantum technical query on off peak and 24 hr supplies
Dear Sir or Madam,
The literature says that dimplex quantum storage heaters need both an off-peak and 24 hour supply - ie: two cables runs back, one to a Consumer Unit for Off peak and the other to a Consumer Unit for 24 Hours. I assume this for the case when there are two meters one for off-peak and one for 24hrs.
In my case I have one meter which is dual tariff economy 7 switched between Normal and Low by an internal clock. This feeds one Consumer Unit.
Since the Quantum has an integral programmer I see no reason why I cannot run one suitably sized cable to the heater from my CU, at the end of which are two switches, one for the storage heater and the other for the fan and convector element. Of course I will have to synchronise the clock of the storage heater with the dual tariff meter's clock and the period when E7 is available.
Am I right please?
Yours sincerely
