Evening all. Working on a bungalow at the minute with the dreaded stramit walls.
All my new cables have been surface, galv capped and the builder is dot 'n' dabbing over. There is an existing radial serving sockets in the living room which is not being rewired. For those that are familiar with stramit, cables are fed through channels in the wallboard either up or down to the loft or floor void.
Do I class cables fed in these channels as reference method 103? If so this would make a 2.5mm radial rated at 13.5A. If that is the case what MCB do I put on that? Doesn't work does it?
